HELP!!! VACUUM LEAK?
Old Apr 17, 2008 | 03:54 PM
chunk's Avatar
Default HELP!!! VACUUM LEAK?
Hey, I have a 3.1L V6 1990 Camaro.. Here is the deal.. I just picked it up and was driving it home and it died out of nowhere... I thought ok? so it started right back up and it ran fine again....right before I got home it died again, this time I was confused, and its not over heating.. I had noticed that the heater was on, so then I turned it off and it started right back up again... It hasn't been driven in a long time(8mo?).. so that probably doesn't help it.
My brother took it for a drive later that day with me and we noticed that when we sit at a light or stop it starts to idle on and off and wants to die, but then you turn on the heater and then idles fine and doesnt want todie.. We're assuming it has a vacuum leak? any other ideas what it may be? anybody have this problem before?
Old Jul 15, 2008 | 07:39 PM
jrsrnr3's Avatar
Default RE: HELP!!! VACUUM LEAK?
Try testing the vacuum heater valve. Its located on the passenger side the smog pump. You cant miss it, just follow the heater core hoses and it runs right to the valve, the other hose goes to the intake manifold. If that dont work then check the other vac hoses. I just got done replacing all my vac hoses and wow what a differece. Good Luck.
Old Jul 15, 2008 | 08:06 PM
MadMikeZ28's Avatar
Since it was sitting for so long you can also give it a few drive cycles so the computer gets a chance to relearn
Old Aug 20, 2008 | 12:36 AM
91riolow's Avatar
if you suspect a vacum leak the best way to rule it out is a smoke test usinga smoke machine unplug the vacum hose that goes to your break booster and fill it through there with the smoke it will make its way through any faulty or broken plastic connectors or vacum hoses indicating where the leak would be
Old Aug 20, 2008 | 12:41 AM
Hmmmmmm...a "One Post Wonder" from 4 months ago?
I have a feeling this guy isn't checking back for an answer.
Old Aug 20, 2008 | 11:41 AM
MadMikeZ28's Avatar
Yeah and3 months after I got suckered in by a 2 post noob! [:@]
Old Aug 20, 2008 | 02:26 PM
ORIGINAL: MadMikeZ28
I think I may have had my Camaro out (east-bound) that same day.
It must have been that "Californi Smog" in your eyes!!!
Is it backing up against the mountain tops again?[8D]
Old Aug 20, 2008 | 03:20 PM
MadMikeZ28's Avatar
ORIGINAL: Camaro 69
Yeah I seem to recall smoke in my lungs that day and that was before all the California wild fires so it must have been you. [:'(]
Old Aug 21, 2008 | 10:34 PM
91riolow's Avatar
wow guys i didnt realize having better things to do than posting everyday was a bad thing i guess i better get to typing to earn your respect ...................haters
Old Aug 21, 2008 | 11:44 PM
ORIGINAL: 91riolow
I think you missed the point. Chunk (the one-post wonder and originator of this post) joined and put this post here shortly after, which was over 4 months ago. He hasn't been back since, so answering to it is a waste of time. Had nothing to do with how much typing you're doing here.
Cory Apple
Mar 28, 2012 11:59 AM
critt86
Aug 10, 2010 12:22 AM
dnulnarts
Jun 10, 2010 09:36 PM
idtem
Jul 25, 2009 06:36 PM
2000blkz28
Jun 9, 2009 12:40 AM
