fule pressure drops
Old 12-16-2007 | 02:57 PM
crusherdrivinfool's Avatar
Default fule pressure drops
ok I hope I am getting close to getting this thing fixed.
but the problem I have now is that when i first turn the key on the pressure jumps up to neer 50 but soon as the pump shuts off it drops rapidly and will only come back up if i crank the motor over.
What could cause the pressure to drop like that?
I had no problems with the pressure befor but had a bad injector so I took it all apart and replaced the injector put it all back together and now it just cranksand dose not start.
Old 12-16-2007 | 08:42 PM
Default RE: fule pressure drops
The pressure is under control of the pressure regulator, and is supposed to drop about 10 PSI after the engine starts. However; it is supposed to hold at the lower pressure once the engine is turned off. There could be a bad check valve in the fuel pump, a bad pressure regulator, a leaky injector, or a plain old fuel leak.
96z28richard
07-13-2014 05:47 PM
jjcrago05
08-04-2009 05:25 PM
nascar9
09-02-2006 10:07 PM
nascar9
08-31-2006 02:56 AM
dzroc
06-14-2006 11:43 PM
