Big Problem..or no?
Old Jun 16, 2007 | 11:53 AM
raiders21289's Avatar
Default Big Problem..or no?
hii guys im new to this forum buh i have a 1986 2.8 liter fuel injected camaro...nd heres the thing...ill start the car and it wont idle...buh if i put a jumper in the box under thesteering wheel the B+A one then itll idle and i loosened the distributor so i can mess with the timing because i think thats the problem buh ive had it timed and it keeps throwin it off.....and it all started wen i heard the engine backfire...now itll back fire on every rev....soo im stumped..can anybody please help me? thanx
Old Jun 16, 2007 | 03:47 PM
Default RE: Big Problem..or no?
Is the check engine lite lit?
Old Jun 17, 2007 | 02:07 AM
yes the check engine light is on..... it turns on after like 2 mins. of running...the acceleration also bogs,it pops near mass air filter when reaching 3 rpm's.
Old Jun 17, 2007 | 11:10 AM
You have to pull or flash the trouble codes (DTC)and it will point youto the trouble that the computer sees.
Flashing codes at DLC connector:
Turn key to OFF
Connect pins A & B together
Turn key ON, do not start engine
The MIL lite will flash code 12 three times (Flash, short pause, Flash Flash, long pause, repeat)
If there are any DTCs, they will now be flashed three times each, starting with the lowest number to the highest.
When all the codes have been flashed, the MIL lite will flash code 12 again, indicating that all codes have been flashed.
Now you need a chart to tell you what each code meant.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
