91 RS 3.1 v6 fuel pump problem...please help...
i just bought a 1991 Camaro RS off a guy for $550
its a 3.1 LiterV65 speed manual...only has 100,000 miles on it
everythings fine
except the fuel pump....the guy said that he replaced it twice in the last 3 years
of course i didnt want to go through the process of dropping the tank so i cut out a small section of the trunk right above the gas tank
only to find that there were 4 steel gas lines leaving the assembly that fits into the gas tank
there is not way to detach these fuel lines anywhere close enough to pull out the fuel pump
i saw on a 4th generation there was a peice of the fuel line that broke apart just for thisaction but my 3rd gen doesnt
i was told to cut the line and replace the small section with a hose
the psi rating going through those lines is in 40's
i dont kno what to do
would someone please help me
thanks, Ryan
everythings fine
thanks, Ryan
