86 2.8 5 speed questions
Just got it a couple weeks ago.mechanic says it most likely needs oil returns cleaned out.how would you go about doing this or where are they at.also i wanna add a lil more power but do not wanna do a v8 conversion. whats some cheap ways to add power to the lil 2.8 im gonna tune it up and was thinking about adding a cool air intake and headers to it but there hard to find i dont know where to look also thought about a cam but is it worth the money/labor i dont know not to knowledgable on the 2.8 motors
wow an early riser. or late and cant sleep? good morning either way. lol. one of the guys thats up a little more than me on the 6s will probly help u out. like gorn or jazz man. im just hangin, cant sleep. body says go fishin and my mind says let them soak. lol internal conflict. lol. im thinkin u can build it up or go with a bigger 6. 3.4 or so.
i would like to be asleep right now but my five and a half month old son decided to get up at six lol not really wanting to change the motor just want to see what i can get out of the 2.8 it seems to be a pretty good motor besides the oil returns being stopped up.the motor come out of a 89 camaro is what the previous owner told me
check this thread out by jazzman. he has a sick v6 build goin.
https://camaroforums.com/forum/93-02-general-41/project-l36-sleeper-40642/
All you need is a case of oil an oil filter and a pair of valve cover gaskets.
The fix is pretty simple. You will need to pull the valve covers and scrap the goop from around the valve. Then you find the oil return holes. Use some wire or a crankshaft brush to clear out the passages that lead back to the oil pan. Reseal the covers
Before you start the motor change the oil (not the filter) Run it for about 20 minutes. Do not rev it. Shut it down now do the real oil change with filter. If you want you can add seafoam or some other cleaning additive to the first oil its no problem since it is only going to be in the car for 20 minutes. I am not a big fan of driving cars with the cleaners in there.
Don't mess with you 2.8 86 saw some nice upgrades but that motor is well known for a weak bottom end. If you need to rely on that car the last thing you need is to increase the power. Many of those motors did not make it out of warranty bone stock. I don't thing its age has made it stronger.
If you really want to play with getting some power and not have the hassel of a convertion think about a 3.4 bottom end upgrade. That is when you take the base block out of a 93-95 camaro and replace your 2.8 block.
A lot of short distance driving is one contributor to sludge buildup. You need to take the thing out on the highway and let her stretch her legs once in a while. Or maybe that wasn't your driving habit, but was from the previous owner.
I thought thats all you have to do just double checking.i know thats the prob you can look in the oil cap on the value covers and its nast. i have been told them motors are junk i had one in a old s 10 and it started knocking.this one seems alright ima probably just put a 305 in it eventually just cant where i live i live in apartments.
