2.8 power?
Nah, same dealio. Plus one of the guys already said that it has a notorious weak bottom. Throwing that on he might as well light his own engine on fire. It would be cheaper and more beneficial to find a 3.8L V6. They only run you like 3-6k. Basically the same as a new engine (or replacing the engine if you do any of that other work improperly). Then you'll come with 200H and 225T stock with a bullet proof engine.
Your cheapest bet would be a strong set of gears if you dont care about MPG. 4.10s would make a huge difference in that car. Other then that its time for a SBC swap.
bore and stroke the block out to a 3.1, swap on some 3500 heads. they're not cheap but guys have been making close to 280whp with them. also, ditch the stock intake manifold, it's not a good high end rpm manifold. you might want to bump the compression up too.
and Gorn, maybe the original sixxer blew up and was replaced by a 2.8??
and as i've said before, you're not going to get any real power out of 2.8/3.1 Iron heads. they don't have the necessary flow for any real performance. 3400/3500 heads will work, and you'll have a better top end performance with them
PCweber
07-11-2012 06:13 AM
