1990 3.1L Stalls Intermittantly
Old 08-14-2007, 08:25 AM
glaugh1's Avatar
Default 1990 3.1L Stalls Intermittantly
Ihave a 1990 camero with a 3.1L. It sometimes stalls after startup, but sometimes it stalls while going down the road. I can only make it short distances. Here is my laundry list of things checked or replaced. I have checked the fuel pressure, new fuel filter, cleaned EGR valve. I've checked IAC, TPS, and map sensors... All are good. It also has a new ECM. The car does not show any codes.
Has anyone had this problem, or have any ideas what to do next?
Thanks for any help!
Old 08-14-2007, 08:21 PM
Default RE: 1990 3.L Stalls Intermittantly
May have an intermittent electrical problem. Does it misfire before stalling or just dies. If it misfires it may be a fuel problem, like the pump losing power. If it just dies, most likely it is in the ignition. Start wiggling switches, wires, connectors, etc., & try to bring the trouble in.
Old 08-15-2007, 07:44 AM
glaugh1's Avatar
It will sometimes run rough. I wouldn't consider it a misfire. More like a running rich condition. I was kinda leaning towards an electrical problem. grounding issue ect... ???? I don't know?
Thanks
Gabe
ShOtzFiReD88
07-12-2011 09:34 PM
drewscamaro
02-10-2011 05:27 PM
AmirGTR
03-13-2010 08:28 PM
new2it
08-18-2007 09:03 AM
gammohr
06-08-2006 01:43 PM
Quick Reply: 1990 3.1L Stalls Intermittantly
