speedometer fluxes
Old Dec 27, 2009 | 07:42 AM
blue max's Avatar
Angry speedometer fluxes
3 months ago i replaced my speedo cable on my 89 iroc z28 because it broke at the trans end. the auto parts had only a one piece unit and not the two piece type that i had. i don't have the ecm or cruise control because i converted to carb ,have 700r4 auto trans. it worked and now it fluxes up and down. i read about vss in the gauge cluster plus some gear in the trans. what could cause this problem. i already checked the cable and it is connected at both ends, not broken.
Old Dec 27, 2009 | 11:25 AM
Could be the cable is binding. Did you lube it up with a graphite bases speedo cable lube? Regular oil or grease will get gummy which makes the cable stick and the needle jumpy.
Camarosc35
82-92 V8 Tech
Apr 11, 2012 10:35 AM
LETSROC
82-92 V8 Tech
Nov 4, 2009 10:45 AM
jezlewis
Jul 16, 2008 11:30 AM
pistolpete_67
Feb 23, 2007 11:52 PM
74Z28
Feb 17, 2007 01:19 AM
