I need some quick help
Old May 2, 2015 | 10:42 PM
96Camaro3.8Cali's Avatar
Default I need some quick help
Now I'm gonna be buying a 91 z28 and I was told the transmission pan has a couple stripped screws, anyone able to tell me the size bolts I need for it, and if I just need to replace the pan? Its an automatic trans. Thanks in advance
Old May 4, 2015 | 07:02 AM
torque_is_good's Avatar
you'll have your answer once you tap new threads into the trans or use a helicoil kit (that has a tap as well)
I'd go with helicoil if it were me
Old May 4, 2015 | 07:03 AM
oh, put white paint on top of those 2 new bolts as they'll be different from the others, or, get stainless steel. Just do something so you can easily differentiate them from the others.
lbaum
Oct 8, 2011 01:16 PM
chadz28
Feb 16, 2011 02:37 PM
x01660
Nov 12, 2009 08:36 AM
sscamaro00
General Racing/Tech
Sep 10, 2007 01:33 PM
