crank but wont start
Old Dec 13, 2021 | 04:02 PM
Dan Blackmore's Avatar
Default no spark from dist
well changed dist retimed engine reset all ground wires plus added new one frame to block power to dist but not plug wires or plugs running out of things to check
Old Dec 13, 2021 | 05:43 PM
Everett#2390's Avatar
First, externally charge battery.
Ensure rotor points to #1 cylinder at TDC and cylinder is on power stroke.
if timing light flashes, then spark is happening.
Has starting fluid been used?
Old Dec 13, 2021 | 08:27 PM
Default still no spark
reset timing took all ground wires off and cleaned installed another ground from frame to block replaced dist tried starter fluid no joy power to dist but no spark to plug wires or plugs running out of things to check also have spark tester tried 3 dist 1 brand new they cannot all be bad
Old Dec 13, 2021 | 08:49 PM
Run jumper wire from battery to distributor
Old Dec 14, 2021 | 11:44 AM
Do these distributors have the 4 wire connector like the one that would have come with the car originally?
If a old school HEI distributer has power and ground and you turn the gear with your fingers it should fire. These are easy to bench test. No way the car can effect the bench test. Most chain parts stores used to be able bench test them for you.
Google or youtube search "how to bench test a gm hei distributor"
Old Dec 17, 2021 | 07:00 PM
okay Gorn bench tested another distributer and got a good spark so put it in the car hooked positive and ground direct to battery hooked spark tester up cranked engine and no spark what is going on any other tips thanks this is 3rd gen 85 Z no air
Old Dec 18, 2021 | 06:12 AM
Reads like no ign circuit power when in START position.
Either switch is worn or needs adjustment on top of steering column.
If starter has power in START, so should ign
You could always add wire from solenoid S terminal to dist power terminal.
Old Dec 18, 2021 | 11:48 PM
The distributor is turning?
A stock 85 would have a 4 wire connector that runs to the CCC system. The computer command controls system controls the timing advance. If there is a a problem with the computer, you could lose spark. If I remember right you can disconnect the 4 wire connector and jump A to C on the distributer side and the distributer should work enough to start. .
Old Dec 23, 2021 | 03:52 PM
Default no start
put new Flame thower coil in have spark to plugs reset timing have gas but still will not fire not a splutter also changed ignition switch
Old Dec 23, 2021 | 04:41 PM
  #20
Did you confirm the dist. is turning when you spin the motor with the starter(cap off watch rotor)? Have you checked compression?
