82 Camaro clutch linkage
Old Mar 29, 2012 | 07:07 AM
Eric Leidich's Avatar
Default 82 Camaro clutch linkage
My son and I just swapped out the 2.8 v6 and tranny with one from another camaro the engine is now a 305 with a 5 speed. ( the car was already a five speed also.) I need to figure out how to run the clutch linkage. the car had linkage but it wil not fit with the v8 in it. I believe that this 5 speed had a hydraulic clutch there is a mount loop on the bellhousing. If so how can I convert it and where can I get the parts I will need?
Old Aug 19, 2012 | 07:24 AM
Edwardgp's Avatar
You should be able to get your brackets and such from a wrecking yard. I would get a new master cylinder for the clutch though.
77nomad
Dec 19, 2009 06:26 PM
uestraven
Nov 21, 2009 11:28 PM
uestraven
Nov 11, 2009 11:46 AM
irocktheIROC
Mar 29, 2009 11:50 AM
83Prostreeter
Oct 9, 2006 07:35 PM
