would subs over the rear end help traction?
im big on good quality audio so im going to be putting a full range soundsystem in my camaro. but i want to know if mounting the subs in the caved down part of the trunk and the amp over the axle will help with rear grip,lifting the front end or weight distribution?
Realistically, a sub won't make much difference. If you want to improve grip, buy some new tires, new shocks, sub-frame connectors or any other type of body stiffening device. Any of those will make a bigger difference than a subwoofer.
A good set of BFG gForce Super Sports will run you around $600. I run them on my IROC, and they're fantastic.
