New rear suspension install
Old May 23, 2015 | 08:26 AM
IROC87's Avatar
Default New rear suspension install
Founders Performance lower control arms with 3 piece rotor bushings, adjustable panhard bar, greaseable poly swaybar bushings, poly end links and Moog IROC replacement springs. Anything else I need to buy before I start the install?
Old May 23, 2015 | 09:08 AM
refreshments.
Old May 23, 2015 | 11:34 PM
MKCoconuts's Avatar
Shocks too.
Old May 24, 2015 | 08:09 AM
blackz87's Avatar
My first choice would be Sub Frame Connectors (SFC) and Shocks the rest is not going to help you.
Old May 24, 2015 | 02:45 PM
IROC87's Avatar
Will be getting weld in sub frame connectors and Koni yellows. Just installing the parts I already have.
I do need to take a trip to the store for refreshments!
Old May 29, 2015 | 10:50 PM
IROC87's Avatar
Ordered the UMI subframe connectors tonight.
Old May 30, 2015 | 07:52 AM
blackz87's Avatar
After you install th welded in SFC's, you will feel the difference right away. SFC's should be the first mod made on any 3rd gen models.
Old Nov 26, 2015 | 03:21 PM
Hell Jes's Avatar
Ok, what should be the second and the third?
Old Nov 27, 2015 | 07:42 AM
blackz87's Avatar
1) Front struts & Rear shocks
2) Front & Rear sway bar bushings and end links
Now with the above and the SFC's you should have tight and good handling car.
Old Dec 3, 2015 | 03:21 AM
Hell Jes's Avatar
Thanks for your reply. Is there a good brand in those things? I want to go for cost effectiveness because I have to have them shipped overseas...
