Speedometer and Tach Wiring- Help Needed!
I have an 89 rs with a 350 carbureted engine and a t56 manual trans. I need to put in a new speedometer and tachometer because the old ones don't work with the trans and i was just wondering on the wiring required to do this. I know i need a power ground and a signal im just not sure how to go about doing it.
By "new tach" do you mean aftermarket? The signal wire (might be a green one) to the tach hooks up to the negative terminal of the coil. Black to ground. Red to keyed power. White to dash lights.
bulldogrsp61
82-92 V8 Tech
May 11, 2011 06:34 PM
