1991 z28 plze help.
"I recently bought a '91 z28 camaro (TPI 5.0L). It came without engine but had factory transmission. To make a long story short my Z28 got primed, and yesterday I lucked into buying an '87 L98 ( 5.7L TPI). The L98 came with the full wiring harness and ecu, headers, etc." so here is my question i need help with.
Any help will be very appreciated, ive waited a long time to own a z28 project car and want "Gamorrah" running. |
when you get the new engine in, the injector wiring should only be long enough to reach just past the injector it goes to. so if you have on hooked up that has a lot of slack in the wires, it most likely doesnt go there. my advice would be figure out where some of the other sensors wires go and base your judgements off of that.
@ z28tallcan
Originally Posted by z28tallcan
(Post 611546)
i updated my questions, cause i have some more. thank you for you response. i look forward to more of your information. (this is my first camaro resto and i'm a green-horn when it comes to mechanical-side of things. |
The TPI injectors are a batch fire. As long as you have the correct injector line on the correct motor bank, it won't matter. Line the harness up to all the other injectors and it should basically fall into place. And Z28TallCan is right, they connectors won't go much passed their injector. But if they're off, it won't change anything, just maybe pull on the wires.
