z28 questions
Old Apr 22, 2007 | 05:02 PM
allamericanman666's Avatar
Default z28 questions
any body know if the 1986 z28 comaro with the 87 350 engine is it a 4 bolt main or a 2 bolt main or how do u find out
Old May 7, 2007 | 11:27 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: z28 questions
more than likely 2-bolt main. Usually the 4-bolt was used for large trucks such as the suburban. pull the oil pan off and you can see
Old May 17, 2007 | 07:20 PM
thats what i heard yet the 350 in it is not the original engine we dont know what it came out of the car is a 86 and the engine is a 87 yet when u take the oil pan off where or what do u look for to see if it is a 2 bolt or a 4 bolt
Old May 17, 2007 | 07:23 PM
350rs's Avatar
March 2008 ROTM
the main caps, there are three of them. It will either have2 bolts on them, or 4. and obviously if it has 2 bolts, its a 2 bold main, 4 bolts, its a 4 bolt main...
Old May 18, 2007 | 04:10 PM
zeus8807's Avatar
just get the codes off the block, its the absolute easiest way to tell, u might have to take a little while to find them but its alot easier than pulling a pan off. type the codes into google and youll get dozens of pages telling u about it.
Old Oct 26, 2007 | 09:07 PM
1981camaroz28's Avatar
The block codes are a great way you can also run the vin number that will tell you everything you need and more
Old Oct 26, 2007 | 11:18 PM
rockin85's Avatar
ive never seen a 2 bolt main 350. 80 % chance its a 4
Old Oct 27, 2007 | 08:38 AM
blackz87's Avatar
ORIGINAL: rockin85
Dumb reply......Because you are blind.
Warpig
Apr 20, 2009 09:33 PM
bigjsmashman
Feb 21, 2008 11:05 PM
nj93zkid
Feb 24, 2007 01:20 PM
dubbs95
Oct 21, 2006 01:29 PM
