yet another problem from coolcat
Old May 1, 2006 | 08:58 PM
coolcat's Avatar
Default yet another problem from coolcat
hell to all the camaro enthusiast
Ok my 89 camaro rs 2.8L is having some problems with the cooling, i recently got the inspection sickers and registration so i was pretty happy that my car was legal to drive, i took it for a spin and in about 5 minutes the cars temp on the gauge was 260!!!! I took it to my cousin who owns an automechanic shop and he checked it out, we left it on idle until it reached 260 and the fan barely turned on!! i recently put a new sensor ( it's next to the manifold), and a new thermostat (190), he told me that the cars fine 'cause the engine wouldv'e been smoking and the heat would've been noticeable if you were standing next to the engine, his guess was that maybe the cooling down process is working fine and the thermostat is working, but that the gauge is messed up and giving you the wrong readings. i don't know about that, i did drive the car for like an hour with the temp gauge all the way up to 260 and the car seemed fine, i even felt the hood and it was cold (* 5 seconds after the hour cruise). What do you guys think???
Old May 1, 2006 | 10:13 PM
Default RE: yet another problem from coolcat
Try changing the temp gauge sending unit. If it works. it is a cheap and easy fix.
Old May 2, 2006 | 01:30 AM
coolcat's Avatar
yes sir
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
