why the heck wont my car run cooler?!?!?!?
RE: why the heck wont my car run cooler?!?!?!?
If your worried about this over heating problem, pull the radiator, take it to a shop, have them boil out the scale deposits in it, if it has plastic side tanks, have them removed, new seals installed. Get a new 190 degree stat and go with a 50/50 mix of antifreeze, this should test good for about -35 degrees below zero. You can also get a laser thermometer and point it at the thermostat housing and compare that reading with your temp gauge, this is accurate to about +/- 5 degrees. Another alternative is to hook in a Genesis scan tool or similar tool and watch the temperature on it, this is what the computer sees and most factual also. Get the fan to start running off the computer again also, this is set up for a reason as noted in prior mentioned posts.
WTG Danzig!!! perfectly put, yeah my fan comes on right at 195 . i had a scanner plugged in to the puter and watched it climb, and also those thermal temp guns work damn good! use one at work everyday, in the asphalt industry. great post later.
ORIGINAL: 350rs
so is that too much antifreeze thing true? i was told that to muchmakes it to thick and it wont flow as effeciantly as it should.
ORIGINAL: Danzig
He stated a new radiator. I never had to have scale boiled off a new radiator. It was also stated a new t stat and 50/50 mix. Wake up man!
ORIGINAL: MadMikeZ28
Did you not read his first post or any others?
ORIGINAL: Danzig
yea, its a brand new rad.
im thinking, arent the tpi engines supposed to have dual fans? mine just has a single fan right in the middle of the rad, and pulls over about half the rad. i know this car has some incorrect peices on it and i thought i got them all, maybe the fan was the last thing?
