Where can I get the codes for the check engine light for a 1991 RS Camaro?
Old Jul 11, 2008 | 09:33 PM
JTNKTZ's Avatar
Default Where can I get the codes for the check engine light for a 1991 RS Camaro?
I am looking for camaros and the check engine light came on. I cannot pass inspection with it lit so before I buy I would like to know what is wrong. So I would like to know on site what the problem is. If I could get a link that would be great.
This is for a:
1991 RS Camaro
Old Jul 12, 2008 | 01:58 AM
MadMikeZ28's Avatar
Default RE: Where can I get the codes for the check engine light for a 1991 RS Camaro?
Do you know how to retrieve the codes? If not check out this link.
https://camaroforums.com/m_126657/tm.htm
Then is the car a 305 TBI or a 3.1 MPFI? You would have to look up codes for either engine. E engine code being the V8 and T being the V6. Some times a code ortwo or more will differ on differentengines
http://www.gmtuners.com/OBD1_DTC.htm
Old Jul 13, 2008 | 09:57 AM
383superstreet's Avatar
when you get the codes out let me know i have a log in for alldata i can tell you exactly what the codes are!!!
87IrocZMan
82-92 V6 Tech
Jul 28, 2010 07:49 PM
Kelgard841
Jun 15, 2010 03:27 PM
track1980
Aug 21, 2009 09:58 AM
91_Camaro_RS
Nov 12, 2008 10:39 PM
