whats my rear end ratio?
when I bought my 84 camaro, it came with the stock, blown 373 rear end, and I was told that the rear they gave me was a posi 373. B4 installing it I pulled cover and yes it is posi, but now I am not sure if its actually a 373 or not. is there a way to lift the rear of the car and spin the tire 1 time and count the input yolk rotations to find out for sure? I have looked a bit here and and found nothing. thanks in advace.
RE: whats my rear end ratio?
Only sure method is to divide the ring gear tooth count by the pinon gear tooth count.
The stamped numbers will tell what it was but if someone had changed the gears you wouldn't know for sure without doing the math.
Here is some reading for you
http://www.jedi.com/obiwan/jeep/misc/gearratio.html
ORIGINAL: Y2Keglide
