Whats the best chip for Camaros
Old Apr 2, 2011 | 03:08 PM
Drexg's Avatar
Default Whats the best chip for Camaros
I was thinking about one
Old Apr 2, 2011 | 03:22 PM
dont even think about it. if you want it done right use a place like this
LT1 PCM Tuning - OBDI/OBDII PCM Tuning/Programming Service
or this
PCMforless.com
Old Apr 2, 2011 | 04:14 PM
ScottD's Avatar
A performance chip for your car with 202,000 miles?
Old Apr 3, 2011 | 11:36 AM
microkid's Avatar
March 2011 ROTM
Technical User
ill second pcmforless.com i have a chip of thiers in my car. without, it simply wouldnt run. its not as spot on as a dyno tune, but its pretty dang close and a lot cheaper than a dyno session
Old Apr 3, 2011 | 11:53 PM
cmcz450's Avatar
Do you normally only see 40hp ish gains, or can you shell out cash for more expensive tunes? Its amazing how much cheaper(I know age plays a factor as well) these tunes are compared to diesels....
Old Apr 4, 2011 | 06:59 PM
one92rs's Avatar
Talking
tuned port or tbi. brian at harris performance inc has tuned many a third gens including mine.
Old Apr 6, 2011 | 08:04 PM
microkid's Avatar
March 2011 ROTM
Technical User
no, its not like a programmer for a diesel. its completely different. a diesel tuner simply adjusts the timing of the injection and the amount of fuel injected. diesel engines respond a lot more to a programmer. as for cars, the ecm can only adjust so much for modifications. minor bolts ons like headers and exhaust and ignition upgrades dont require a tune. more in depth things like cam, heads, and higher compression do. but putting a chip into a stock engine may net you about 10 hp. into a well modified engine, it can be a difference as to whether or not it runs, not just a power increase
Old Apr 7, 2011 | 08:11 AM
blackz87's Avatar
The best Prom (chip) for your ECM is the stock factory one, Only reason to change is, if you made some serious mods to your engine, Otherwise forget it, there is no magic bullet that is going going to increase your horsepower.
czaj1992z28camaro
May 18, 2011 05:50 PM
kdm212
Jun 2, 2009 11:25 PM
355CAMARORS
Oct 7, 2006 10:28 PM
92rscamaro
Nov 12, 2005 01:27 AM
1hottcamaro
Sep 18, 2005 07:58 AM
