what should I do?
Old May 22, 2006 | 12:49 AM
wig's Avatar
wig
Default what should I do?
My car is 305 tbi car. Ihave a 98 350 vortec with a carb setup.how good wood the vortec run on tbi?
Old May 22, 2006 | 02:52 PM
Default RE: what should I do?
I ould guess it would run OK, and the power should be about the same, but you will need a TBI manifold to bolt to the Vortec heads. Personally, I would avoid going to TBI as I see no advantage to it, a TPI or a Holley injection would give better results.
Old May 24, 2006 | 02:47 AM
wig's Avatar
wig
pete If I went tpi , hows the best way to do it?
Old May 24, 2006 | 10:12 AM
blackz87's Avatar
Not worth the time, money and effort. Too much to change from the TBI to TPI setup and nothing on your car is compatible for that TPI swap..
Old May 24, 2006 | 12:58 PM
The Vortec heads do not mate up to the TPI manifold. You may try a MPI injection from Holley or Edelbrock, but I am not sure they will fit either. Scoggin & ****ey advertises a TPI lower intake baseplate to fit Vortec heads, which will mate up to TPI runners, this is probably the best bet. You could also check out the FI system used by GM on Vortec V8s. In all cases you would need the appropriate computer and wiring harness.
Old May 27, 2006 | 11:39 PM
wig's Avatar
wig
thanks guys. as usual can't make up my mind let you know when I do.
