What rear end is in my car?????
Old Feb 3, 2006 | 08:27 PM
92camaro305's Avatar
Default What rear end is in my car?????
im looking around to buy a set of 3.73 gears for my camaro and i was wondering what rear end would be in my car, it was originally a v6 car if that makes any difference
Old Feb 4, 2006 | 12:27 AM
HaloNick's Avatar
Default RE: What rear end is in my car?????
What year is your car? Auto or Manual? This site should have more than enough info:
http://www.thirdgen.org/newdesign/tech/techdb.shtml
Old Feb 4, 2006 | 11:57 PM
Pull the rear cover, the ratio is usually stamped on the pinion gear, otherwise count the teeth on the ring and pinion gears and do the math.
Old Feb 6, 2006 | 03:04 PM
gmpartsguy's Avatar
Your local GM dealer can pull up the rearend build codes for what origanlly came in the vehicle from you VIN number.
Old Feb 7, 2006 | 01:36 AM
v8chvyguy's Avatar
It's more than likely a 7.5 or 8.5 inch 10 bolt. On the ring gear (the larger gear) there will be a long series of numbers stamped on the edge facing you, towards the end of that chain there will be two-two digit numbers ie: 41 11, 41 10 and so on. these numbers represent the tooth count of both gears. all you have to do is divide the larger by the smaller ie: 41/11=3.727=3.73's and 41/10=4.1=4.10's. I would suggest taking it to a very reputable drivetrain shop. They will know exactly what kind of rear end to get gears for and whether or not you'll have to change carriers. Once the gears have been MOUNTED, not installed, you own them they cannot be returned. My boss has made alot of money off guys who bought the wrong gears over the internet. Stay away from Motive Gear, and Yukon thier gear sets are sht and don't like to set up worth a crap. Primarily Precision Gear and Spicer is what we have always recomended and used on customer work.
Old Mar 28, 2006 | 11:49 PM
blackz87's Avatar
92 RS with a 305 auto had a 10-bolt 2:73 using a open 2 series carrier. Its not worth the money for install 3:73 gears in the rear you now have. And the reasons are too many to list.
blackz87's Avatar
Old Mar 29, 2006 | 04:50 PM
nitrosnowpunk's Avatar
i dont know what these other guys are sayin not saying there wrong but im pretty sure in order to find out what gear ratio is in your car if you look on the axle housing there should be i believe its there letters and a number stamped into it you might have to take some of the grim if any and rust if any off to see it or there should be a tag on the rear end cover. Then if you have the manual or a service manual for your car those numbers should be in there somewhere and that'll tell you for sure what you have in your car. Hope that helps
Old Mar 29, 2006 | 06:54 PM
hsdragracer's Avatar
nitrosnowpunk is right - theres a code stamped on the axle housing and u just match it up to the cars manual book
Saaampson74
Oct 20, 2008 04:56 PM
libertyforall1776
Nov 10, 2007 03:04 PM
