what compression for a twin turbo setup ?
Old Dec 18, 2009 | 06:38 AM
freaky's Avatar
Default what compression for a twin turbo setup ?
i know forced induction creates compression so with that being said i'm wondering what you guys are running compression wise on twin turbo or blower motors ?
thanks
Old Dec 18, 2009 | 08:12 AM
All depends on how much boost you plan to use.
Old Dec 18, 2009 | 08:20 AM
freaky's Avatar
say i decide to run 9-1 pistons how much boost could i run if say i'm running twin 50 trims .call it a 350 motor dart heads
is there a stickie on here of building a twin turbo'd small block ?
Old Dec 18, 2009 | 09:18 AM
SpecterGT260's Avatar
Ninja Administrator
it still depends. your weak points on a (properly tuned) forced induction motor will be the crank, rods, and possibly the pistons (but those will be more temperature sensitive). Stock 350 internals probably wouldnt appreciate much over 9psi - so twin 50 trims really are over doing it. if you want to boost big look into forged internals first
Old Dec 18, 2009 | 09:36 AM
freaky's Avatar
alright give me some idea of what internals i'll need to hold 15-20 lbs of boost
Old Dec 18, 2009 | 12:35 PM
It really does not matter how many turbos you want to use, what matters is the amount of boost. 15-20 PSI doubles the normal air pressure. Theoretically, all else being the same, that should double the power, but it won't. Inter cooling is almost a must. For the engine to live with that boost it is going to need forged pistons, rods, crankshaft, and 4 bolt mains. Also it would be best to hold the compression ratio to no more than 8:1, in order to control detonation and keep the engine in one piece. The low compression will make the engine soft at the bottom end until the turbos spool up, that is why I prefer superchargers.
Old Dec 18, 2009 | 12:58 PM
freaky's Avatar
thanks for the info ,my last car had 8.5 -1 pistons but it was a 4 cylinder . i knew i needed fairly low compression to pull off twin turbos , i will use an intercooler plus a meth injection kit . what do the v8 guys use to tune with ? i was tunning on my last car with a piggy back settup , do they make such a thing for this car ?
Old Dec 18, 2009 | 07:23 PM
microkid's Avatar
March 2011 ROTM
Technical User
the larger piston bore also requires a lower compression than the 4 cylinder. thats why a large displacement engine will run around 8.5:1 CR to run on 87 octane, but a small bore 4 cylinder can run 10:1 or higher and still run on 87 detonation free.
as far as tuning, what do you plan on running? factory style fuel injection, aftermarket fuel injection, carb?
and as far as the motor itself to handle 15-20 psi, you will need forged pistons, rods, and crank. i also suggest a main cap girdle, valley girdle, and head studs to keep the block from cracking.
now, i was just reading in my camaro performers magazine about a twin turbo first gen. its a 407 sbc, individual throttle body fuel injected running turbonetics 60-1 HIHI P-trim at 10 psi. their compressin is 8.25:1. the shop that built the car was prodigy customs www.prodigycustoms.com i suggest maybe contacting them in reference to the project "Motiv8er" and they could direct you to the engine builder
Old Dec 18, 2009 | 09:05 PM
freaky's Avatar
thanks man ,i'm still in the planning stages thats why all the questions .
i'm thinking i'm gonnas go with carbs maybe a tunnel ram an dual 4 barrels with twin 50 trims . i'm planning on getting a 12bolt rear end an using 3.73 gears .i syill want it to be streetable . i'm gonna check out this company you gave me the link to .thanks again .
Old Dec 25, 2009 | 09:10 AM
freaky's Avatar
anybody else ??????????????
96V6Camaro
Oct 11, 2021 09:41 PM
Mikeystang
Nov 28, 2007 06:42 PM
z28ster
Dec 20, 2006 05:43 PM
casper
Jan 24, 2005 04:16 AM
