Well.. After
Old Nov 4, 2006 | 12:55 AM
Corr182's Avatar
Default Well.. After
just back the 91 z28 305 tpi back from the tranny shop, had it rebuilt. Runs pretty good, when u drop it down into 1st and gas it, runs very strong pretty good service. Just one question, I know this might be dumb but my PCV vavle is ticking, and u can hear it at idle I should replace it right? thanks
Old Nov 4, 2006 | 12:58 AM
Corr182's Avatar
Default RE: Well.. After
im sorry also, when i turn left at night my overhead DOME light comes on, when i turn right it doesnt does anyone have a soultion???
Old Nov 4, 2006 | 11:38 AM
uncle bill's Avatar
Replace the PCV Valve, I don't have a clue about the dome light thing unless a door is ajar.
Old Nov 5, 2006 | 03:22 AM
FlufyTiger's Avatar
Check the headlight switch. When you turn the dash light dimmer all the way up, at the end of that is a switch to turn the dome light on. The wire's probably loose and shorting over the switch and turning the light on.
Old Nov 5, 2006 | 10:06 PM
carguylt1's Avatar
The latch may be adjusted out to far on the door. so when you turn it lets the prassure off the switch.
Old Nov 6, 2006 | 03:27 AM
MadMikeZ28's Avatar
The latches dont adjust. You can adjust the switches in the jamb though.
There is the button leading into a tube and then the nut. Use some plyers and grab the tube, but not tight enough to crush, and pull out on the tube a little. Close the door and it will push back in as far as it needs to go in.
