Weird Headlight Problem
Old Nov 25, 2008 | 05:56 PM
ShiftyMcCan's Avatar
Default Weird Headlight Problem
When I turn on my headlights only one light turns on but when I turn on my brights the other three come on and the one that was on previously goes off. Any ideas whats causing this? If you don't get what I mean, please refer to me wonderful illustration below ...
X - Light that is on.
Normal Headlights
[ ][ ]______[ ][X]
Brights On
[X][X]______[X][ ]
Old Nov 25, 2008 | 06:20 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Default RE: Weird Headlight Problem
Headlight switch sounds like the culprit....
Old Nov 26, 2008 | 03:39 AM
jim022659's Avatar
try switching the 2 out lights and see what happens. if the problem reverses then you have 2 partially burned out lights. if not then yes its a switch issue. the low beams may also have a 2nd filiment for hi beams. this happened to me many years ago.
Old Nov 26, 2008 | 12:53 PM
MadMikeZ28's Avatar
Replace the two outer headlights. There are two filaments in them and more than likely one in each is burned out.
Old Nov 30, 2008 | 02:54 AM
Quick update: When I have my brights on now all four of them kick on. It has been like this for a few days so far, but with the brights turned off it still is just the one headlight that turns on.
@ MadMike: Can I just replace the bulb or do I have to get a whole new headlight?
Old Nov 30, 2008 | 03:12 PM
MadMikeZ28's Avatar
Unless it has been changed for a different headlight system you need to replace the whole square light. Its a sealed beam. You may want yo wiggle the connections. Maybe even put some dielectric grease on them. I have also seen where the pin on the back of the light would break loose.
ztwentyate
Apr 14, 2015 11:32 AM
wolfy692005
May 19, 2010 11:23 AM
80rsguy
Apr 12, 2009 03:54 AM
hevymetalg
Oct 11, 2008 06:42 PM
JayBarker
Feb 22, 2008 07:38 PM
