Weight reduction
Old Mar 11, 2010 | 02:35 AM
Barnett1217's Avatar
Default Weight reduction
Any suggestion on how to drop some weight off my 92 camaro? (without getting rid of anything major like seat) Any ideals would be appreciated!!
Old Mar 11, 2010 | 08:53 AM
blackz87's Avatar
Have the driver go on a diet. Everything major in the car is what weighs the most. Everything else is non-factor unless you want a bare interior, with no a/c, heat, defrost, radio etc..etc. Just what do you want to accomplish with this idea of yours??? 91 RS in its stock form is no drag car no matter how much it weighs......
Old Mar 11, 2010 | 07:02 PM
microkid's Avatar
March 2011 ROTM
Technical User
if you dont want or use the a/c, you can lose about 30 lbs there. do you have emissions? if not, and if it has an air pump, you can remove that. dont carry around garbage either, or extra clothes, or subwoofers. and chances are your spare tire is flat because no one ever checks the spare until they need it. and btw, the factory jack doesnt really fit under the car if it has a flat. you can remove that stuff, and just carry a can of fix a flat and an air pump instead. anything else removed is going to be stuff you see or need
Catmaigne
Aug 14, 2011 09:33 PM
User Name
Feb 4, 2010 11:13 AM
Envisi0n91
Oct 9, 2009 08:59 PM
user 7208220
Sep 15, 2006 04:04 AM
gotalcoholmanup
Aug 7, 2006 12:29 AM
