v8 swap...evap canister?
Old Jun 10, 2007 | 03:02 PM
1985RS's Avatar
Default v8 swap...evap canister?
hey guys, i just had a question, i pulled the fuel injected v6 out of my camaro and am putting a carb'd v8 in it. i've already pullled out the ecm, ecm wiring and all unneccesary connectors out, and i was wondering if i NEED to keep my evaporation canister or if i can junk it? any help would be great..
Old Jun 10, 2007 | 03:43 PM
Default RE: v8 swap...evap canister?
You can get rid of it, butyou need to plug up all the EVAP hoses attached to the tank.
Old Jun 10, 2007 | 05:00 PM
1985RS's Avatar
right on thanks Pete. all the hoses i really need to keep is the big one off the brake booster correct?
Old Jun 10, 2007 | 05:37 PM
Danzig's Avatar
Yes for the brake booster, however you will need something to control the valve on what I call the climate control switch for your heater. One for vacuum advance and depending on the tranny, you will need one there also.
Old Jun 10, 2007 | 06:55 PM
MadMikeZ28's Avatar
One of those hoses on the evap is labeled vent for the tank. Don't close off the vent
Old Jun 10, 2007 | 10:11 PM
1985RS's Avatar
vent for the fuel tank?
Old Jun 11, 2007 | 01:43 AM
MadMikeZ28's Avatar
Yes a vent for the tank. I may be wrong about the word. It may say "tank"
Old Jun 11, 2007 | 06:50 AM
1985RS's Avatar
ok well that shouldnt be too difficult to get around, thanks.
Old Jun 11, 2007 | 02:05 PM
MadMikeZ28's Avatar
Yeah I have seen non working tank vents cause them to implode
Old Jun 11, 2007 | 05:41 PM
1985RS's Avatar
well as long as i dont block that line it should be fine right? i'm assuming the tank vent is the vacuum line that follows the rear brake lines?
