V6 to v8 conversion
Old Mar 22, 2007 | 09:13 AM
creed777's Avatar
Default V6 to v8 conversion
I was reading about changing a v6 to a v8. I saw how v6 tranny's are smaller and need to be replacedand becompatible with the 305/350 motor. What other things need to be done? I question the rear-end, front end (weight), and electrical ie: gauges tach, etc...
Now with this being said, what absolutely needs to be done after the swap and what can wait?
Old Mar 28, 2007 | 09:24 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: V6 to v8 conversion
just need the accessory side of the engine wiring harness, the computer and motor mounts. the rear would hold up to a 305
Old Mar 29, 2007 | 01:04 PM
uradumass5695's Avatar
You will need to change the tranny, ecu, wiring harness, motor mounts, exhaust, fuel pumpand i believe the speed sensor.The suspention in the front will be fineit is the same, and the rear end is the same as well just with different gear ratio's. 88-92 v6 carshad a 3.23 rear end and the v8 cars had a 2.73 rear end so you should leave the v6 rear end alone. You may have to remove it to drop the gas tank to do the fuel pump though.
NEVERLETITDIE
Mar 8, 2010 11:06 PM
RubberDucky
May 8, 2009 04:42 PM
stangslayer
Dec 19, 2007 02:31 PM
davefh
Aug 6, 2007 08:40 PM
davefh
Apr 3, 2007 10:05 PM
