Unstable Idle
Old 09-17-2009, 02:57 PM
91RS_Convertible's Avatar
Default Unstable Idle
My 91 RS (305) does the weirdest thing ... When sitting at a light, the idle will randomly switch between two different RPM's (from the nominal 1500 to about 2500). While in the higher rev state, she runs very poorly. However, when she drops back down to normal RPM's she runs great ...
I've been to a couple shops (and of course she runs GREAT in front of a mechanic) trying to track this down ... but as of yet have gotten nowhere.
Any ideas ?
Old 09-17-2009, 03:03 PM
Have you ever given your engine a tune-up? My RS used to do the same thing when I first got it. Replacing the plugs, wires, distributor cap and rotor cleared it up. I'm certain mine was either a bad wire or a carbon tracked cap.
Old 09-17-2009, 05:27 PM
Default tried that ...
Yeah, she has new plugs, wires, cap, and rotor ...
Old 09-17-2009, 07:16 PM
microkid's Avatar
March 2011 ROTM
Technical User
nominal 1500?!? it shouldnt idle higher than 1000 unless its cold. anything that high is either a stuck idle air control valve or a large vacuum leak
Old 09-17-2009, 07:46 PM
The Idle Air Control value has already replaced ... No vac links, checked that too.
Nevertheless, neither of those would cause the idle to oscillate to that extreme ... the RPM's almost double instantly, and in after a few minutes it goes back to normal.
Old 09-20-2009, 12:33 AM
carguy68ssrs's Avatar
Check all your vaccum lines for cracks. sounds like when one of the vaccum switches opens you get the problem, also check brake booster valve
Old 09-20-2009, 11:56 AM
microkid's Avatar
March 2011 ROTM
Technical User
i still think its crazy that it would do that. are you sure the engine is going that high and not just the gauge?
Old 09-20-2009, 01:39 PM
Crazy, but rather discouraging. I'm not going to swear to the accuracy of my stock tach ... but the running idle (whatever it may actually be) does in fact almost double. You can hear and feel the change.
Now what about Air/Fuel mixture measurements? Could a faulty sensor have that much effect on the idle?
Old 09-20-2009, 01:41 PM
... the brake booster value? I wouldn't have thought to look there ... ?
r00tk1ll
02-06-2015 10:25 PM
Rustyshackleford1911
12-27-2014 09:32 AM
hawkins183
02-15-2012 11:34 PM
internaldifference
01-23-2009 01:32 PM
6v49der
01-03-2007 01:51 AM
Quick Reply: Unstable Idle
