two questions
two questions
one whats the easiest way to replace the heater core and how long will it take. and two, under hard initial accelleration i get a nice little thud. at first i thought motor mount, tranny mount, shock mount. all these checked out good. then a buddy of mine said lower control arms. any one else got an idea??
thanks
thanks
RE: two questions
it sounded like the things i mentioned. feel it in the floor. sometimes theres a little wheel hot along with it and its only under hard shifting or accell. by a loose drvie shaft do you mean u-joins?
RE: two questions
What you describe sounds like a trans mount. Did you check the mount by jacking up slightly on the tail of the trans? A torn mount doesn't always stick out like a sore thumb.
