trying to get some ideas on paint
Old 07-01-2008 | 06:25 PM
black89rs's Avatar
Default trying to get some ideas on paint
all right guys i'm looking to paint my 86 iroc but not sure what color to use....i was thinking about going with a midnight black metallic. but the paint is very expensive....i'm looking for a decent color at a reasonable price.......any ideas???
Old 07-01-2008 | 08:04 PM
MadMikeZ28's Avatar
Default RE: trying to get some ideas on paint
Red is always a good choice
But also you can look for less expensive paint manufactures. Like Sherwin Wiliams has thier less expensive Dimensions. They also have Western but that stuff is good for work trucks! Check the parts stores in your area to see what is availibe. Also some Crapa (napa) autoparts sell automotive paints
Old 07-02-2008 | 01:51 AM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
What colour was it originally?
Old 07-02-2008 | 03:28 AM
MusicMan's Avatar
The Jazz Man
two tone would be cool, red and metalic silver. I like metallic paints, but in single stage, it doesn't spray right. The metallic "specs" droop and sag, the paint does not dry fast enough. This makes it spendy to do it right. To do it right, it needs to be a base coat/ clear coat system.
Cost wise, red is the most expensive, usually. If you go single stage paint, stick to your primary colors, blue, yellow, red, etc.
Old 07-02-2008 | 04:44 AM
MadMikeZ28's Avatar
I would think with his name the original color would be....BLACK!
As for metalics doing things when it single stage that is just because the nut on the handle of the paint gun is screwed up. That same nut can just as easily screw up a base coat metalic.
Old 07-02-2008 | 05:32 PM
black89rs's Avatar
ya i only use 2 stage paints.im not a painter by far but ive done a couple and they havent come out to bad....i thought sherwin williams was house paint [>:][:'(][sm=headbang.gif][sm=headbang.gif]. and the car was originally yellow...the black comes from my 89. i got some prices but they were like 250 for a gal. they said it was cheap
Old 07-02-2008 | 06:10 PM
MadMikeZ28's Avatar
Sherwin Williams also has automotive paints. And depending on how well the paint covers and if your doing jambs you should not need a gallon. Unless you are spray happy
Also if you use a HVLP spray gun you get more paint on the car than in the air so you will use less.
Some will not cover as well. The scoop I put on my hood used about 1/2 pint of red. Thats because I did not seal it and the red was slighly transparent. I know from using a lot of Dupont Chroma base and PPG DBU that they use a high solids coloras thier sealer. If you were going red you would get a high solids pale red as a sealer.
Old 07-02-2008 | 06:19 PM
bigjim's Avatar
I think it would look awesome go for it. I'm going to paint my 4th gen hugger orange base with whitess stripes anduse a flattening agent in the clear. It should look like orange suede when i'm done.
Old 07-02-2008 | 06:34 PM
bigjim's Avatar
Also look into the duplicolor line they have a single stage system thats super cheap ( I think its laquer based) wich is super easy to spray do a little wet sanding a machine buff it out.
Old 07-02-2008 | 09:50 PM
bigjim's Avatar
Heres the link it is a laquer system and it's ready to spray!
http://www.duplicolor.com/products/paintshop.html
manslaughter299
07-16-2012 01:52 PM
Devin's camaro
03-07-2011 07:12 PM
Devin's camaro
03-05-2011 10:26 AM
Ceelo912
10
07-25-2010 03:47 PM
sja5150
04-28-2008 01:41 PM
