Transmission Help
Old Dec 27, 2006 | 11:58 PM
Goodfella's Avatar
Default Transmission Help
So i am in the process of buying a car and i test drove this 1991 Z28 with the 350, 3.23posi, auto, etc. and was going through the paces and it shifted from stop to first to second perfectly, but when it was time to shift into 3rd, its like it just shifted into neutral. I do not know the condition of the fluid but i was wondering if i am looking at a nightmare of buying a new trannyor a simple filter/fluid change. Is this a common problem? Please help.
Thanks
Old Dec 28, 2006 | 12:13 AM
Default RE: Transmission Help
Change the fluid & see if it makes a difference, but I doubt it is going to fix your trouble.
Old Dec 28, 2006 | 12:27 AM
MadMikeZ28's Avatar
**** and moan about the tranny being screwed up and get it cheaper. Then ya have the money to fix it
Old Dec 28, 2006 | 12:29 AM
Goodfella's Avatar
Yes ill prolly do this anyway. if it is not the fluid. is there another possibility. clogged filter perhaps.Also does the OBD set codes for tranny stuff or only in the engine?
Old Dec 28, 2006 | 12:49 AM
MadMikeZ28's Avatar
The only computer controled item in the 700R4/4L60 trans is the Torque Converter Clutch. No shift solenoids or anything else.
Old Dec 28, 2006 | 10:54 PM
Goodfella's Avatar
I was looking through other forums and some other people were having the same problem. they said that one of the valves was sticking or something? I have absolutely no knowledge of how transmissions work, no matter how long i look at the cut aways and exploded views... nothing. please help me out.
Old Dec 28, 2006 | 11:14 PM
MadMikeZ28's Avatar
I always had rebuilders do it so cheap for me I never messed with the inners. You could get many answers but I think the bottom line is your going to have to expect to pay a tranny shop to open it up to fix it.
Old Jan 1, 2007 | 11:32 PM
Raven91Z28's Avatar
Sounds like the servo is worn out. This was common on the 700R4's. The 2nd to 3rd shift was really weak and would flare. This was the case when I bought my 91 Z. Yours just soundsexceptionally bad if it's like going into neutral. TCI sells a heavy duty servo for this problem. It has "surface area up to 63% greater than stock providing an additional 300 lbs of 2nd gear band apply force. The TH-700R4 servo kiteliminates the common 2nd to 3rd flare problem. This kit can be easily installed without removing the transmission or draining the fluid." You could just put one of these on and it should fix it. Here's the link. It's about 1/2 to 3/4 the way down the page.
http://www.tciauto.com/Products/GM/gm_4L60E.asp
Old Jan 2, 2007 | 02:01 AM
Goodfella's Avatar
What would happen with the flaring problem. i am unfamiliar with anything transmissions. [&o]sorry
Old Jan 2, 2007 | 06:44 PM
OMGLS1's Avatar
Humm. 700R4's from 86' and Up were suppose to be the good ones. That's too bad... Mines rock solid still and its an 84'. muwahaha
