TPI ?
Old Aug 23, 2006 | 07:54 PM
Mikevogel's Avatar
Default TPI ?
does anyone know if the Tuned Port Injection manifold off a 5.7 350 will go on my 5.0 305 and if so anyone know how benificial that will be over my throttle body injection thanks
Old Aug 23, 2006 | 08:13 PM
350rs's Avatar
March 2008 ROTM
Default RE: TPI ?
it will fit, the injectors are larger than what your 305 needs, but you could prolly get away with leaving them in, youll just go through more gas, i dont know if it will be benificial for power or not though... i would think so.
Old Aug 24, 2006 | 12:34 AM
IROCZJON's Avatar
Default RE: TPI ?
it should my boss swapped a 350 intake on his 305 1992 convertible and it fit and drives ok so i dont see why not
Old Aug 24, 2006 | 10:32 AM
blackz87's Avatar
Default RE: TPI ?
If you have a 305 TBI engine, you could use the Intake off a 350 TPI. But you would need a lot of other parts to make it work, such as the wiring harness, ECM & Chip ,MAF sensor intake and other sensors. My opinion would be its too much work and Not cost effective.
