timing marks
Old Sep 17, 2012 | 10:17 PM
juice+'s Avatar
Default timing marks
I bought an 350 engine out of an 88 z28, and i put a new timing kit in it while it was out of the car. Now its in the car all hooked up and i cant get it to run. Im pretty sure its a timing issue, it turns over but wont catch, and back fires out the intake a lil bit. I brought the first cylinder up to top dead center, and reset the distributer at least 5 times now, every thing looks like it should work but its not running. Now when i put the timing kit in the engine, my hanynes manual told me to align the marks on the two sprockets so that the top one is at 6 oclock and the bottom one is at 12 oclock. But i looked it up on my friends computer and it showed the marks at 12 and 12 oclock. So i pretty much pulled most of the front of the engine off so i could get to the timing chain again, and am planning on switching it to 12 and 12, but the haynes manual clearly says 6 and 12. wtf does anyone know which is correct?
Old Sep 17, 2012 | 10:26 PM
BasicConcepts's Avatar
Technical User
everything im seeing online says 12 and 12
Old Sep 17, 2012 | 10:43 PM
juice+'s Avatar
well thats good news, i dont want to pull all that stuff off for nothing. thanks
Old Sep 17, 2012 | 10:46 PM
Technical User
usually a backfire means 180 out so either cyl 1 is at bdc or the cam is upside down.
Old Sep 17, 2012 | 11:18 PM
How do you put a cam in upside-down?
Take a look see at the illustration below. 12/12 is correct for TDC #1. You can set the marks facing each other with the engine at TDC #6, but then turn the engine over to TDC #1 before doing anything else. TDC #1 on the compression stroke is what you always want to pay attention to when installing the distributor.
Old Sep 17, 2012 | 11:28 PM
A2TURBO's Avatar
Banned
thats frickin hilarious
Old Sep 17, 2012 | 11:34 PM
If this guy installed the cam upside-down, and the distributor inside-out, he's really gonna be lost!
Old Sep 18, 2012 | 02:13 AM
Technical User
you guys know what i meant... sheesh...
Old Sep 18, 2012 | 07:34 AM
YAV8's Avatar
The proper way is to have the top sprocket dot at 6 and the crank sprocket dot at 12. When you install the distributor like this you will need to FIRST rotate the crank 360 degrees and ONLY THEN set the distributor with the pointer facing between the water neck and the valve cover. AS OF NOW you only need to reinstall the distrubutor 180 degrees and you should be set. The crank turns over TWO times for the cam to rotate ONCE. You can do a 12 to 12 or a 6 to 12 and the timing will be the same, just remember the 2-1 crank to cam. Pointer to the front or to the back depending on the timing chain marks. JUST ROTATE IT 180 DEGREES before you do all the work over first and try that.
Old Sep 18, 2012 | 12:03 PM
I think we may be getting overly complicated with the TDC #1 and #6, turn this, rotate that info.
What it boils down to is.... timing gear marks pointing at each other = TDC cylinder #6 compression stroke.
Both marks at 12 o'clock = TDC cylinder #1 compression stroke.
With both marks at 12 o'clock, the distributor rotor wants to point to the #1 wire on the cap.
