those gorilla chipz
Old 10-28-2006, 01:33 PM
91_camaro's Avatar
Default those gorilla chipz
hey you guys seen those gorilla chipz on ebay right? the ones that are stage 2 and promise like 38 to 60 more horespowerwith install time less than 10 minutes? Well do they really work? If so would it make a big difference in my car, a 91 camaro 305 tbi? Thanx!
Old 10-28-2006, 05:02 PM
blkmgkcamaro's Avatar
March 2007 ROTM
Default RE: those gorilla chipz
they made a huge difference on my dads 91 corvette. (350 tpi) dont know if it will help on a camaro though. im guessing it would.
Old 10-28-2006, 07:16 PM
SickSickSick's Avatar
It’s a resistor that tricks your PCM (computer) into thinking that the air temperature is colder than it actually is. This tricks the PCM into advancing the timing and changing the Air/Fuel ratio. it's crap. not a real chip. don't buy it. Sick
Old 10-29-2006, 06:12 AM
MadMikeZ28's Avatar
Sick is right
I saw somting like that and in the pic it was a resister. You bid on a radio shack $0.10 piece and he charged 4 or 5 bucks to ship it in an envelope with a .39 stamp.
If you want to try, check the resistance of your air temp sensor at cold and get a resistor the same value and stick it in the plug. But be warned. this persons feedback had complaints of fires and such.
Old 10-29-2006, 01:53 PM
91_camaro's Avatar
actually I dont have a air temp sensor in my intake. Any other ideas? Please keep them coming.
Old 10-29-2006, 04:27 PM
MadMikeZ28's Avatar
actualy you do from the underside in the back of you air cleaner. Keep em coming
Old 10-30-2006, 01:35 AM
91_camaro's Avatar
Oh sorry I forgot to mention I have an aftermarket breather/cleaner(which ever u want to call it) and I dont have any sensors in it what so ever.
Old 10-30-2006, 03:25 AM
MadMikeZ28's Avatar
well there should still be one somewhere. When you unplug stuff like that a check engine light would come on.
Old 10-30-2006, 11:55 AM
shnormo's Avatar
Well http://www.installuniversity.com/ins...m_9.202000.htm That will help answer your questiosn and even give you the Ohms for the resistance if you want to go to radio shack and buy a much much cheaper one. The air temp sensor, if it gets unplugged most of the time will not trigger the MIL.
Old 10-30-2006, 10:09 PM
MadMikeZ28's Avatar
Well I know when I have forgotten to plug mine back in when I reinstall the air cleaner because it triggers a light. The computer sees it as an open circuit.
Quick Reply: those gorilla chipz
