Third brake light not working.
Old Oct 30, 2010 | 07:53 PM
Mike86IROC's Avatar
Default Third brake light not working.
Anyone had trouble with the third brake light on an 86?
Old Oct 31, 2010 | 07:04 PM
microkid's Avatar
March 2011 ROTM
Technical User
theres a few ways of it having trouble. are the bulbs good? is there power at the sockets if they dont light? if there is no power, check the wiring where i goes from the body to the hatch. the constant movement can break the wires inside the insulation
Old Oct 31, 2010 | 07:42 PM
Mike86IROC's Avatar
No voltage. I will look deeper. thanks
Old Oct 31, 2010 | 07:49 PM
microkid's Avatar
March 2011 ROTM
Technical User
ok. check where the wires flex at. i had the same issue with my 95 blazer. mine was inside the rubber body grommet. cut it out, spliced it back together and it was good. a few other members have had the same issue and found that same problem
Socom
Nov 9, 2013 01:41 PM
Camaro3800V6
Jul 17, 2013 06:33 PM
hpd218
Aug 24, 2010 12:05 PM
Skiwee10
Aug 31, 2006 12:54 AM
