is it suppose to be like this?
Old Nov 24, 2009 | 03:09 PM
mighty mike's Avatar
Default is it suppose to be like this?
ok when i put this motor in my grey 1 it sounded like this--
http://www.youtube.com/watch?v=JpLuyoRdwXw
same exact motor with egr blocked off in my new maro--
http://www.youtube.com/watch?v=9HhAbAQDCAQ
nothing else was touched. it sounded the same b4 i took the egr off. is it suppose to make that big of a differnce?
Old Nov 25, 2009 | 08:42 PM
microkid's Avatar
March 2011 ROTM
Technical User
no, it shouldnt make any difference in sound at all. the egr is only supposed to function while the engine is under load. im currently experiencing egr issues on my blazer where it is stuck partially open, and my idle lopes like that. it sound wicked, but it shouldnt sound like that. im thinking the timing might be advanced too far, it sounds like its trying to burp out of the carb. something is off other than jus the egr
Old Nov 25, 2009 | 10:16 PM
if i turn my dist down ne more itll stall out.
Old Nov 25, 2009 | 10:26 PM
machine1999z28's Avatar
kinda sounded like it was missfiring when you revved it
Old Nov 25, 2009 | 10:42 PM
tried to adjust the idle air fuel? sounds like one side is starving.
Old Nov 25, 2009 | 10:44 PM
another double post. seems more logical for it to be rich.
Old Nov 26, 2009 | 11:22 AM
microkid's Avatar
March 2011 ROTM
Technical User
yes, does sound like a misfire as well. check to make sure you have all the plugs wires on the right cylinders. ive done that before, and i know of someone who thought their engine was about to blow up because he had 4 plug wires that were on the wrong cylinders
Old Nov 26, 2009 | 12:12 PM
i hooked up my air/fuel guage and it says its running rich. but see thats wut doesnt make sense, cuz all i did was block off the egr port on the manifold. and didnt touch nothing else. would it sound like that if it had a cam? cuz i was thinking that when the egr was on it was a big vaccum leak and made it run high like that. and blocking it off would solve that vaccum leak. right?
Old Nov 26, 2009 | 01:15 PM
does it run the same after it warms to operating temp?
Old Nov 26, 2009 | 05:49 PM
yes..
