that stupid check engine light
Old 10-14-2006, 11:31 AM
350rs's Avatar
March 2008 ROTM
Default RE: that stupid check engine light
codes 12, 15, and 44 all popped up... wonderful...
Old 10-14-2006, 07:30 PM
ajk511's Avatar
12 is just the handshake code. no worries. did this myself today and got 43. guess i gotta replace the knock sensor.
Old 10-14-2006, 08:50 PM
350rs's Avatar
March 2008 ROTM
na i wasnt worried about 12, its the other two thats got me wondering a little more.
Old 10-14-2006, 11:19 PM
MadMikeZ28's Avatar
Dont get worried yet. You replaced the O2 now replace the coolant temp sensor and disconect the battery for 10 to 20 seconds and it will clear the codes. Then drive it a while and see if they come back.
Old 10-15-2006, 12:42 AM
350rs's Avatar
March 2008 ROTM
yea, that temp sensor is probably bad. i messed it up pretty bad when i changed the headers... the system needs to be flushed anyway.
Old 10-15-2006, 06:00 PM
MadMikeZ28's Avatar
The temp sensor is on the intake manifold. Should have a yellow and a black wires. The sender for the gauge (the one located on the head with a green wire) does not send any signal to the computer.
Old 10-15-2006, 08:44 PM
350rs's Avatar
March 2008 ROTM
is it??? well shoot, i destroyed something on the passenger side of my engine below the number 6 cylinder. i managed to rig it so it will work for now... but is that NOT a temp sensor? when i broke it my engine over heated and the fan wasnt comming on. thats what lead me to believe thats what it was. but yall know more than i do... so i noticed there is a sensor or SOMETHING on the thermostat housing. is that what im looking for?
Old 10-15-2006, 08:47 PM
FlufyTiger's Avatar
If it's something like the sending unit with you swapped earlier, yeah, that's it exactly. Should be a pretty easy piece to get to, if I remember correctly. I know the pigtail connectors like to go bad in that section of the wiring harness, too, and they're cheap and easy to change, so you may wanna pick one up with the new thermistor.
Old 10-23-2006, 05:54 PM
350rs's Avatar
March 2008 ROTM
so that light of mine, it just,,, stopped comming on. its on when i first start it like it should be so its not burnt out. Do yall think that it might have just takin the computer a few days to get to know the new equipment? i sure hope so. otherwise i just opened a can of worms i dont want.
  #20
Old 10-23-2006, 08:25 PM
MadMikeZ28's Avatar
The computer may have relearned after a few drive cycles.
Chevykicksbut
10-28-2009 07:14 AM
91ralllysport
09-22-2009 03:04 PM
1989_RALLYSPORT
02-24-2009 02:23 AM
bill12690
11-26-2006 04:22 PM
DZllr
10-27-2006 12:27 AM
Quick Reply: that stupid check engine light
