starter help asap!!
Old Nov 17, 2006 | 03:08 AM
motor tec's Avatar
Default starter help asap!!
I cant firgure out whats going on. theres four red wires that go to the starter with fuseable links an one main lead to the batt. well tonight i was driving an the car stalled when i went to go start it back up it wouldn't fire so i had my buddy push me to the shop (it was only 2 blocks) we got it in the shop an i took the air cleaner off an went to start it up the batt died. when we tried to hook the batt charger up to it.. the termanel arced crazy. i put it on the hoist took the starter off, an it was hott as hell. i put a test light on the wires an the three wires that hook in to one eye hole contector and it lights up but the single one doesnt an the remote does. im so lost. why would it light up an where do those three wires go. i cant figure it out.. help please.
Old Nov 17, 2006 | 03:40 AM
MadMikeZ28's Avatar
Default RE: starter help asap!!
Those fusable links are supoosed to get power off of the battery cable that hooks to the starter. If you had the diconected from that cable and they were hot then you need to find where they are getting power from.
Do you have a chiltons? If not I could scan and e-mail some pics of diagrams that may help you.
Old Nov 17, 2006 | 03:46 AM
MadMikeZ28's Avatar
Check those links. Sometimes the wire wont burn away but it comes loose inside the plastic part. I can only think of two right now. One goes to the alt for voltage detecting and the other goes to the headlights and tailights. They might go up to the junction block and maybe one goes to the ignition.
Old Nov 17, 2006 | 04:16 AM
motor tec's Avatar
ok well we found the problem..... theres a main feed wire for the fuse box or some sort. it runs to the fire wall on the drivers side. then into the car. i cant fine where it go's from there but i do know that its grounding out. I dont have the time nor the money to fix this car anymore. im fed up sick an tired of it. So this is what im going to do. Im going to sell every single part. Best offer take what ever part. no matter what it is. this will be limited time thing do to space time an money. i will how ever wait atleast one week. then my buddy going to pick it up an flat bed it to the crusher. so if there anything you want let me know asap. like i said best offer takes what ever part you want. i will wait bout one week. my EMAIL is motor_tec@hotmail.com
1991 camaro RS
T-tops are in good condtion
350 in good condition
700r4 trans is good
rims are the 16in 5 spoke
body pannles are good
windows are good
suspension is good
hatch is good
pretty much every thing is good
except.....
interior is ok
wire harness is bad.
Old Nov 17, 2006 | 09:40 PM
MadMikeZ28's Avatar
Your just frustrated and cant blame yourself for that. Breath.....Count to ten.....in latin......if you have to just pull the whole dash out, its not hard at all, and trace the wires and repair them. You have done so much , try not to give up so easy.
Old Nov 17, 2006 | 10:57 PM
SickSickSick's Avatar
it's very simple to run a new hot lead to the fuse box. anything worth having never comes easy. Sick
dlaidoutranger
Jul 3, 2012 02:19 PM
newschoolharley
82-92 V8 Tech
Feb 23, 2010 09:27 AM
barblima123
Feb 24, 2008 08:43 PM
kickboxer
Dec 3, 2007 10:18 PM
KrazyHobo
Nov 15, 2007 10:34 PM
