spiked tack
RE: spiked tack
With the engine off - it indicates 3500, right? That's what you mean?
You could try removing the clear cover over the instruments, pulling the needle off the spindle it rotates on where it is now (pointing at 3500) then pushing it back on (gently, gently) with it pointing to 0. Then reinstall the cover. This MIGHT fix it
