speedo helppp
Old Dec 5, 2009 | 11:45 AM
Good idea, but first make sure the speedo on the Stang works. But not to worry, you can always trade the Stang for a Renault that may have a good speedo.
Old Dec 5, 2009 | 11:50 AM
^ Lol...what better reason to go from a Camaro to a Pustang than because of a speedometer problem? Come to think of it, I don't recall ever hearing about Yugo's having had speedo problems either. The possibilities for a sure fix are endless!
Old Dec 5, 2009 | 02:13 PM
91ralllysport's Avatar
lol real funny guys the only reason im thinking about switching to it cause its light emissions exemp and it has a bigger engine by 1 c.i.
Old Dec 5, 2009 | 02:22 PM
and its not tired like the camaro
Old Dec 9, 2009 | 02:04 PM
how do i find the ratio of the rear end its snowing so i dont wanna do it by lifting the car and turning the wheels are the rear ends tagged or something?
Old Dec 9, 2009 | 08:18 PM
op codes will tell u what was in the car when it was manufacured. i think there in the glove box on the 91 but not sure could be in the center consol. its a list of letters and numbers that tell u what options are in your car. gu2 is a 273 ratio gu5 is 323s i think gu6 is 342.
Old Dec 9, 2009 | 09:02 PM
i dont have a glove box so it would be on the sticker that in the center on the side of it?
Old Dec 9, 2009 | 09:15 PM
The code will tell what was factory installed, and what might still be in the rearend. But there's no guarantee that a previous owner didn't once upon a time change them for a different ratio. Nothings more certain than a twirl test or a visual check.
Old Dec 11, 2009 | 09:39 PM
idk this car was raced and in result the original 305 was blown and 350 dropped in but never put new computer in so it throws random codes but dam i really dont feel like sitting on the cold wet ground and rotate the axles
Old Dec 11, 2009 | 09:53 PM
  #20
mighty mike's Avatar
your codes are on the little compartent cover in the hatch.
GU2-2.73 RATIO
GU4-3.08 RATIO
GU5-3.23 RATIO
GU6-3.42 RATIO
GU7-3.73 RATIO
GU8-3.90 RATIO
GU9-3.91 RATIO
