speedo helppp
one of a kind probem. lol. so have u cleaned all your grounds? battery, junction box? make sure your motor strap ground wire is not broken. i thinkin the speedo unit may be a gremlin home. lol.
ive checked everything ive even been kicking and puching the dash thinking it will work but still no luck and with no money i cant go out and replacing parts that may be it cause im poor making minimum wage dam economy!
I'm thinking it might be the speed sensor on the transmission is bad. As the engine warms up, so does the trans. Logically, that's the only speedo related thing that's subjected to heat. Have you checked the wire connection at the trans too?
