speed chip
Old Apr 9, 2007 | 05:03 AM
darion45405's Avatar
Default speed chip
ok, i am sure everyone has seen the "speed chips" on ebay. I was wondering what they do exactly, and if they are so great why doesn't everyone have one?
Old Apr 9, 2007 | 11:59 AM
StratcatDeville's Avatar
Default RE: speed chip
I was wondering about these last week myself
and all the knowledgeable people here said stay away
from them. They are scams! You can get the same resistors at radio shack....however there are the EXPENSIVE chips, like hyptertech and such, that DO work but with only minimal gains and personally I dont know if they are worth the money.
Old Apr 9, 2007 | 12:35 PM
microkid's Avatar
March 2011 ROTM
Technical User
the resistors on ebay are just ****. all they do is fool the ecm into making your car run like crap. however, real computer chips do have a performance gain as they alter the fuel curve, ignition curve, and a few other parameters, and work well if you have other things already done
Old Apr 9, 2007 | 01:45 PM
The so called chips, actually plain old $0.10 resistors, screw up the IAT sensor or the ECT sensor and make the computer believe that the intake air or engine coolant temps are colder than actual. The computer then causes the FI to deliver more fuel. This makes the fuel mixture richer then needed, causing driveability problems, poor mileage, and even loss of power. To make max power with good driveability, you need the proper fuel mixture, not a rich mixture.
Old Apr 9, 2007 | 04:53 PM
350DREAMS's Avatar
they do nothing so dont waste ur money.. kk
Old Apr 10, 2007 | 12:50 AM
Raven91Z28's Avatar
I got a custom chip for my setup. I went to a 383 and had fuel injectors from a Z06, Dart heads, big cam etc. and I sent all of the specs of my heads, cam, fuel system, etc. to this guy and told him how I would drive it and how it would be used (pump gas etc). He burned me a custom chip to my setup (cam heads and everything) and it only took a week. He was awesome to work with and fast. The motor ran perfect and has for two years with no problems. It was also only 90 bucks. My friend got one from him too last year and it was about $110. But still, that's pretty cheap. Don't get the ****ty ones on Ebay where you don't really know what you're getting. This guy was at tbichips.com. HIGHLY RECOMMENDED!!!
Old Apr 10, 2007 | 01:21 AM
You got a real computer chip, The stuff on E bay is not a chip, but just a resistor.
Old Apr 10, 2007 | 02:00 AM
MadMikeZ28's Avatar
There is harrison chips or something to that effect on ebay. they are real proms. You can only tell because they are more that .99
Old Apr 10, 2007 | 02:03 AM
MadMikeZ28's Avatar
rext
67-69 V8 Tech
Sep 23, 2011 11:49 AM
mikeylikesit
Jul 9, 2007 09:56 PM
Pesho
Feb 18, 2007 01:07 AM
