Some questions...
Hi everyone, I'm new here. Got a question for everyone. I bought a abandoned 92 camaro from a guy but he doesn't have the original keys. Now I was able to get a key that can fit the lock and ignition but the computer isn't recognizing the chip, aka the car won't turn on. What should I do? Any suggestions? Thanks
idea is get the code for the key from a dealer though the VIN# ,another thought is there should be a way to bypass the computer ,or not,sure there are other options,lock smith
Bypassing the Vats system is easy if you know the resistance of the key. There are 15 options for resistors. If the dealer can not tell you which one you had then the process get a lot more complicated.
If the car has a dealer decal somewhere on it that is the dealer to call. Back in the day only the original dealer location had the info. Course that assumes they kept the info. Automotive and Commercial Locksmith: VATS System Chart Check you tube on how to bypass the Vats system but without knowing which resistor you have you will need to start guessing, https://www.walmart.com/ip/DIRECTED-...&wl13=&veh=sem |
