Shutting off when i give it gas
Could be a bad TPS sensor. You might short Pins A & B together in ALDL connector (OBD !) and just turn on IGN and count pulses of CE light for getting trouble codes.
I'm sure OBD ! instructions are around somewhere. You can use a tire pressure gauge and check fuel pressure, since OBD 1, about 13 PSIG.
