Shift kit!!
Old May 20, 2006 | 03:38 PM
bjc72488's Avatar
Default Shift kit!!
I need help understanding what exactly a shift kit does. And what does a 411 gear mean?
thanks
Old May 20, 2006 | 07:33 PM
Default RE: Shift kit!!
A shift kit is modification kit that makes an automatic transmission shift firmer than normal. It generally requires removing the transmission oil pan, making changes or replacing parts, usually to the valve body.
A "411" is an abbrevated way of describing a final drive gear ratio. The proper expression would be 4.11 : 1, which means, in case of a rear drive car, that for every 4.11 turns of the driveshaft, the wheel axle will make 1 turn. Also means that the torque provided by the driveshaft is multiplied by 4.11 times, while the rotational speed is divided by 4.11 times. There are many different gear ratios available, depending on need.
Old May 21, 2006 | 12:13 PM
bjc72488's Avatar
Thank you for the info it helped alot!!!
apetsel
Mar 25, 2011 06:27 PM
bigtim1985
Sep 29, 2010 11:28 PM
th3po1son
Jan 20, 2008 08:56 PM
KoRN_Munky
LS Series Tech
Mar 25, 2007 02:49 AM
94Z28SHAKER
Jul 11, 2005 02:38 AM
