Running 220*F on camaro
Old Apr 3, 2010 | 10:18 PM
RS camaro's Avatar
Default Running 220*F on camaro
My camaro is running 220*F I just changed the coolant and put a 180 stat on. No change. Is this normal or what should I do. Fan does work already checked.
Old Apr 3, 2010 | 10:41 PM
duf6's Avatar
yeah it's normal but you could get an aftermarket fan switch from jet that kicks on at a lower temp.
Old Apr 3, 2010 | 11:18 PM
RS camaro's Avatar
How much would that cost?
Old Apr 4, 2010 | 07:27 AM
blackz87's Avatar
220 deg is normal in traffic, what dose it run on the highway???
Old Apr 4, 2010 | 08:43 AM
duf6's Avatar
summit racing and year one have the switches for around 60 bucks i'm sure jeggs would too.
Old Apr 4, 2010 | 09:16 AM
blackz87's Avatar
Once you start hacking into the ECM to control the fans with a manual switch, just leads to other problems. Since front of the raditor is hidden no one looks at it as a problem, but 20 yrs of crap on the cooling fins will make it run hot.
Old Apr 4, 2010 | 09:40 AM
duf6's Avatar
^^good point
Old Apr 4, 2010 | 10:34 AM
ScottD's Avatar
You can get a new, stock radiator for 100 bucks at Napa. Its a very easy swap and you will notice a cooling difference. 20 year old, gunked up radiators just arent as efficient as they need to be.
Old Apr 4, 2010 | 10:57 AM
Jr. Mechanic's Avatar
August 2009 ROTM
The gauge could be off too. I would verify that it's running hot with a manual gauge before you start throwing parts at it.
Old Apr 4, 2010 | 11:11 AM
RS camaro's Avatar
^^^ I think I will do this. It runs 220*F through town sometimes only 190-200 but on the interstate and highways it always runs 220-230*F It may not get up to 230 but it goes just a little over the 220 mark sometimes. To change the radiate will I lose all my bran new coolant?
