replacing the "hatch pull down motor" with something else?
Hello everybody
I'm from Europe and I have 89 Camaro. I broke my hatch pull down motor 2 times please don't ask me why :) Is there an alternative way to keep trunk down without a motor? any welding jobs or alternative parts available? I need your help. |
you could just unplug it, loosen the bolts and move the pulldown to where the trunk will close and it will just operate the same as a non motorized one. assuming the latch still works of course.
I would recommend stop doing whatever you are doing that is breaking the motor! Mine is 17 years old and still working fine.
mine is 24 years old and works fine
I could be wrong here, but I think the motor is necessary in preventing the back window from being broken, you know like if you slam it too hard the glass might shatter where as allowing the motor to pull it down makes it much easier on the car.
In response to your question about alternatives, I'd suggest ordering the metal housing unit for the motor from Top Down Solutions. I had to replace the same part on my z28 yesterday because the plastic housing broke and am about to order this part so I don’t have to do it again! |
Originally Posted by adirtypoostick
(Post 315971)
Originally Posted by mighty mike
(Post 344383)
ive had to do that a couple of times..but the motor is nesserary.
(Post 344383)
| All times are GMT -5. The time now is 05:53 AM. |
