removing an engine out of 87 camaro z28
Old 05-25-2013 | 10:16 PM
Junior Golombeski's Avatar
Default removing an engine out of 87 camaro z28
I have a 1987 camaro z28 5.0 tbi im planning on taking the engine out, its my first camaro n engine removing my question w my 5.0 tbi how hard is it to remove the engine I have a cherry picker anything n advice would be very helpful thank you
Old 05-27-2013 | 10:02 PM
moved your thread to the 3rd gen general tech section for you. go slow keep it safe. welcome to the forum, enjoy.
Old 05-28-2013 | 05:39 PM
djs383's Avatar
Agree with Craby. If you are placing the same motor/style setup back in, make sure to label everything. I recommend colored zip ty's with a master notebook explaining what each is. Example double red=knock sensor.
Take a few photos if you think too much time will pass and make your memory foggy. Take the time now to figure out if you are pulling motor/trans as a unit, or separate. Do be careful if you've never done this before. It took me three nights after work (5-8 PM) to pull motor, radiator, trans, driveshaft, etc.
Old 05-31-2013 | 03:02 PM
microkid's Avatar
March 2011 ROTM
Technical User
try to cut as little as possible, label everything, and use pb blaster when needed. theyre really not all that hard
6.5 Detroit TD
12-13-2010 10:46 PM
Luz Hernandez
10-21-2010 07:12 PM
Michael Snyder
82-92 V8 Tech
05-19-2009 11:32 AM
94z
09-29-2008 02:10 PM
rockin85
03-07-2008 11:17 PM
